rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
DarrellRiffe
Sep 02, 2017Apprentice
By the way ... Don't quote ONE SENTENCE of my message in a response designed to denegrate me ... and then when I respond with info that was pretty much included with the original post, with NOTHING. Doesn't help anybody AND NOT APPRECIATED.
I am done with this...
RogerSC
Sep 02, 2017Virtuoso
DarrellRiffe, I'm glad to hear that you've found a good solution to the problems that you were having. Hope that the Linksys continues to work well for you.
- ukwildcat4life7Sep 03, 2017Aspirant
Hello everyone. I purchased the RBK50 system back in March and it worked fine until the last firmware update so for the last month or so its been sitting in my closet and I am using a single router that is working fine but of course I'd prefer to have my $350 orbi system going. I have read throughout this thread that some of you were lucky to get a beta firmware sent to you by netgear. I read that the only way we can get this firmware is to contact support through this forum? I tried that and whenever I input my serial number it shows that my complimentary 90 day support expired in June and it would not let me go any further unless I paid for some premium gearhead support......so am I correct in saying that I will have to wait until netgear releases their next firmware or is there another way I can get access to the beta firmware? any input much appreciated... thanks in advance!
- gbjacksonSep 03, 2017Apprentice
Purely anecdata, but it seems like the best way to get their attention is to give it a one star review on Amazon. They seem to monitor that much more than they monitor this forum.
- Bing-StrollerSep 03, 2017Luminary
gbjackson, very true actually.
Although I did not leave a review on Amazon UK, I did use it to make contact and had a very quick response when dealing direct.
For that I have to give a big thumbs up to "NETGEAR Support Team" ( thanks Neil )
- RogerSCSep 03, 2017Virtuoso
Bing-Stroller wrote:gbjackson, very true actually.
Yes, Neil is a great guy, and has been a big help!
- scornwellSep 03, 2017Apprentice
I'm glad others are having a better support experience than I am. My support guy is friendly and helpful enough, but he takes days to reply to any messages (I'm guessing he's pretty overloaded) and so far all he's offered up is an older version of the beta firmware that doesn't address my issues at all, not that that's his fault. The latest beta doesn't help either.
We're now a week shy of the two month mark and the situation still doesn't look great.
- Mods still haven't responded in any meaninful way, despite regular tagging. To be fair, I don't think there's much they can say.
- Beta firmware appears to resolve some issues, but just like with V1.12.0.18 most of those fixes don't survive a reboot.
- The workaround which would have kept customers happy in the interim, allowing users to disable auto-updates, has not been implemented and doesn't look like it will be. Thsi is pretty unforgivable given how many customers are asking for it and how simple and quick it would have been to release. Policy first, customers second.
So it seems Netgear know what we want better than we do and don't feel we deserve any transparency with regard to progress on the issues. This isn't the fault of the mods here, the community or support people were talking to, it appears to be awful, backward, company policy.
I've given up and moved on to Google WiFi, which so far is working great. The backhaul speed is marginally lower, but in real-world usage it's not at all noticable, and it's a happy compromise for a router that doesn't drop the internet connection at least once a day and doesn't have crippled internet throughput for those with gigabit fibre connections. The software is considerably more polished too, if that's important to you.
Unfortunately I can't sell Orbi in it's present state, so for now I'm stuck following this thread. - nxcSep 03, 2017ApprenticeI went and gave Orbi a 2-star review on Amazon. It’s a well-earned score in my view.
- Tigerman4LSUSep 03, 2017Star
Has anybody tried the AmpliFiHD setup? I am leaning towards trying it. Tired of the fighting the Orbi.
- RogerSCSep 04, 2017Virtuoso
Tigerman4LSU wrote:Has anybody tried the AmpliFiHD setup? I am leaning towards trying it. Tired of the fighting the Orbi.
I've heard good things about the eero gen 2. Both the pack with the one main unit and two beacons, or the pack with the three main units.
I would look into the IPv6 situation, though, before going that way, if you need IPv6 now.
- cinekSep 04, 2017Apprentice
can't say I have many issues with the orbi either (touch wood). The main issue I had to start with was when the DHCP lease expired, eveything would disconnect for a few minutes but I've changed it to last 999 days. I've also set most of the devices (inc the orbi router & satelite) to use static IPs on my existing router (orbi is in AP mode). Unfortunately the existing router can only support 10 IP reservations hence why I had to extend the DHCP lease timeout period. Not sure if this help anyone.
the only annoying thing now is that all devices which are connected to orbi are coming up as unknown
- jdpg2Sep 04, 2017Apprentice
My observations thus far
- So far for all my wireless devices (except my S8+ ) have worked well with the Orbi.
- Finding the "sweet spot" distance between the main hub and Satellite is key for having wide coverage and not having the devices step on each other.
- My S8+ drops all the time even after receiving Verizon's last update.
- Wired devices connected to the Satellite have HORRBILE performance (>10mbs), so much so I had to resort to an AC Extender.
- When performance becomes subpar you need to reboot the Orbi , which I now do weekly (would be nice to have a reboot scheduler)
- Once you open a ticket the support team seems very responsive, but is reluctant to push you to level 2 without much back and forth
For completeness, my Orbi is in AP mode sitting behind an Untangled u25 router. I have gone through a complete refresh of the firmware including an nvram reset and I am running Firmware 1.12.0.18.
My firmware requests
- Ability to designate 2.4 from 5 ghz wireless networks (much like what is being offered in the Orbi Pro, same hardware different packaging)
- Ability to turn down the 2.4 signal strength, it currently swamps the 5ghz at distances where 5ghz would perform better.
- Ability to choose if you want to update to the next Firmware update
- Ability to reboot devices on a schedule (would be better if you didn't have to reboot boot but this is consumer grade hardware)
- Better monitoring tools in both web ui and phone apps
- Stop dropping my Samsung S8+
I am hoping that support will send me the links to the new beta firmware that is to be released shortly so I can see if there is any improvement.
Also 90 days of Hardware support is ridiculously short for a device of this cost and that is provided with the current subpar firmware. 6 months would have been more appropriate since we are all, in essence, beta testers at this point.
I think what we are all experiencing here is a company trying to push out all their shiny new hardware before they have the supporting firmware fully baked.
- Retired_MemberSep 04, 2017
jdpg2 wrote:My observations thus far
I agree with all you've said, except my Chromecasts, Echos/Dots, Surface Pro (2017) and Surface Pro 3 all have had problems with the 1.11 and above firmware UNTIL the 2.00 beta.
Now, everything is back to rock solid, EXCEPT the S8+. The Verizon update from Samsung had no effect on WIFI since nothing was included in the update that affects WIFI (this is verified by Samsung themselves).
So now, Orbi is back to being well behaved except for the S8+ as it was prior to 1.11.x.
Both my Surface 4 Pro and Surface 3 Pro work without issue, so clearly there is some inconsistancy ... Can someone provide a link to the beta software? I have been back and forth with Negear support but now i have to wait another cycle to get to the lvl 2 support.. They are responsive but really want to have you go through some hoops to get to what you need.
- cinekSep 05, 2017Apprentice
and all my devices connected to the sattelite just dropped off. Could not access the satelite using a PC connected via ethernet either. Seems like it died for about 10 minutes. As I'm still within the 30 day return period (5 days left) I'll be giving linksys velop a go as Netgear seem to be taking ages releasing v2. Best of luck ppl
- bwherrySep 05, 2017Star
...and my satellite was disconnected again this morning. Sigh. I might have to give that beta firmware a shot...
- n4choSep 05, 2017Apprentice
bwherry wrote:...and my satellite was disconnected again this morning. Sigh. I might have to give that beta firmware a shot...
I was having nothing but issues with the satelites disconnecting and my devices losing connection. I had the beta firmware from the link when it was available and decided to pull the trigger on Saturday. My devices have not lost internet access a single time where previously it would happen 5 times in 2 hours.
As others have posted I am sure there are some issues outstanding but it has improved my experience to the point where I am totally satisfied and may unsubscribe from being notified of posts in this thread :)
For the record, I flashed, erased the NVRAM, factory defaulted and reconfigured everything from scratch. I did NOT run the speed test. I am a happy camper for the first time in a while :)
- ikjadoonSep 05, 2017Star
^^ I'd be cautious, though. That's what everyone said about the .18 update (for those who don't know, we've been experiencing these dropouts widely since March this year--as more people buy Orbi, more people suffer and post here).
It's like a merry-go-round of frustration: some people get off and ostensibly even more get on with the next firmware, even though most beta testers felt "really optimstic this one will really fix the disconnection issues". Somehow that didn't translate into actual stability in the final release.
I'm not counting any eggs until I see everyone with multi-manufacturer dropouts (i.e., the whole network, not a single device) state that the Orbi now performs as stably as a $400+ router should.
- scooterman2Sep 07, 2017Tutor
I am a new Orbi owner (1 week) and have been following this thread. Interestingly (knock wood), I have not had the stability issues mentioned. I am running V1.12.0.18 for the router (RBR50) but for the satellites (RBS30), V1.12.0.4 is installed and shown as "no new firmware version available". For some reason, V1.12.0.18 for the satellites never installed and I am not about to do a manual install given the problems mentioned here.
Just wanted to share my situation in hopes that it might help someone.
- Hydro130Sep 07, 2017Luminary
I'm fortunate that I'm not having any issues with the current firmware, but I'm definitely eager to check out the v2 when it's released out of beta.
I have a feeling that one big reason that Netgear hasn't publicly released it yet is because they want to verify it more thoroughly with the official/public iOS 11 release (which should drop next week).
