rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Dustin278
Sep 07, 2017Apprentice
Pichontech wrote:
Dudes, the beta firmware absolutely fixed everything for my system. iPhones, Nvidia shield, laptops, Google pixel, Ethernet all works no one drop for a week +. One guy in a previous post linked the post that had the beta firmware. Get it from there if you don't want to wait until the next update. I can tell u that I won't change the beta even with future updates. Do a clean install. Best luck. Orbi when working is by far the best out there and I tried the eero 2nd gen pro.
I had linked the Beta but I believe one of the MODs deleted the link. Yes mine has been flawless with the Beta for over a week.
scornwell
Dustin278 wrote:
Pichontech wrote:
Dudes, the beta firmware absolutely fixed everything for my system. iPhones, Nvidia shield, laptops, Google pixel, Ethernet all works no one drop for a week +. One guy in a previous post linked the post that had the beta firmware. Get it from there if you don't want to wait until the next update. I can tell u that I won't change the beta even with future updates. Do a clean install. Best luck. Orbi when working is by far the best out there and I tried the eero 2nd gen pro.I had linked the Beta but I believe one of the MODs deleted the link. Yes mine has been flawless with the Beta for over a week.
Try rebooting your router and see if it's still flawless.
- Dustin278Sep 07, 2017ApprenticeMy router has been rebooted 5+ times.. I've never had the speed problem that you always talk about
- Dustin278Sep 07, 2017ApprenticeI have cable internet and my speeds are also lower than yours.. I can only get 65mbps down and 6mbps up.. doesn't change and never have I messed with my nvram
- scornwellSep 07, 2017Apprentice
Dustin278 wrote:
My router has been rebooted 5+ times.. I've never had the speed problem that you always talk aboutUnless you have a gigbit internet connection, Orbi in router mode and possibly VLAN tagging involved, you may not experience the same issue as me. 65Mbps is less than 8% of my internet connection and roughly the same speed my Orbi maxes out at on the latest firmware. So how do you know you're not experiencing the same issue?
You've rebooted your router 5+ times in the last week?
- Dustin278Sep 07, 2017ApprenticeYes sir. I've moved my router a couple times which involves unplugging it, and I've needed to restart after a couple setting changes.. you can stop over and restart it if you want..
