rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
scornwell
Sep 11, 2017Apprentice
Is anyone who is reporting success with the latest beta actually using the routing functions of their Orbi?
It's seems madness to me to purchase a $500 Orbi kit and only use it as an access point when you could have acheived the same by adding a second, much cheaper, WiFi router to your existing setup. Especially those with internet connections which are unable to take advantage of Orbi's backhaul.
spinkick
You don't buy an orbi for its routing capabilites that are minimal at best. You used a dedicated router and let the orbi do what it's best at, backhaul bandwidth and coverage
- scornwellSep 11, 2017Apprentice
Both are fair answers, but the target market for this device seems to be the non-technical, not people who are likely to set up a dedicated router. Though I guess they're the same people who will be quite happy plugging this into their ISPs router, so maybe I'm the odd one out here!
There's no denying Orbi has a fantastic backhaul when it's all working correctly.
- Fila13usSep 12, 2017InitiateHi, can someone tell me where I can get the beta? Thank you.
- cinekSep 12, 2017Apprentice
you need to raise a support ticket and ask for it
- ukwildcat4life7Sep 12, 2017Aspirant
Can you tell me how to create a support ticket and ask for the beta firmware if I'm past my complimentary 90 day support? thanks in advance......
- jdpg2Sep 12, 2017Apprentice
https://www.netgear.com/support/contact.aspx
If you are beyond the 90 day you will need to purchase support. I think its the Gearhead option.
- tomsliwowskiSep 12, 2017Apprentice
I'd like to know what magical routing capabilities you're looking for in a home router that can't be filled by the Orbi. I went from an R7000 running XWRT (and prior to that DD-WRT) to the Orbi and I've not missed any routing duties that the R7000 was doing.
Now if you're runnig a home lab or a very complex network then maybe but if you are, the majority of consumer hardware is probably not for you.
Using the Orbi as an AP seems like a huge waste of money.
100% disagree, If it's a waste of money can you show me a cheaper AP that'll handle my gig up/down connection and cover the whole flat/house at the same time?
Handling a gigabit up/down on a LAN can be done by ANY AP so I don't see how that's relevant.
As for coverage, sure, grab yourself literally any mesh system from Google, Eero, TP-Link, etc and you'll be saving between $50-100.
ok let me rephrase, how can I get the max speed out of my wifi with google wifi or eero or linksys velop for that matter which I just returned due to it being 100Mbps-200Mbps up/down slower? and no, not every AP will handle a gig up/down. I tried many in the past on just a 300Mbps connection which failed to get above 200Mbps
Well let's take a step back then. Are you testing your speed being hardwired to the RBR, being connected wirelessly to the RBR, hardwired to a satellite, or connected wirelessly to the satellite?
Hardwired to the RBR I expect full gigabit up/down (or the closest consumer-grade approximation thereof).
Wireless to the RBR I expect somewhere around 60% of the max speed so figure ~520Mbps
Hardwired to the satellite I'd expect aroud 575Mbps
Wireless to the satellite I'd expect to look somewhat like a wireless connection to the RBR with an extra latency hop so around 520Mbps.
Now this is all assuming you're within line of sight and no other devices are talking at the same time.
I'd expect a Google WiFi or Eero to perform the same on the hardwired portion and at least similarly when conected to the main unit (the one connected to your WAN or LAN.)
I'm talking about the wireless speed here
- st_shawSep 12, 2017Master
tomsliwowski wrote:I'd like to know what magical routing capabilities you're looking for in a home router that can't be filled by the Orbi. I went from an R7000 running XWRT (and prior to that DD-WRT) to the Orbi and I've not missed any routing duties that the R7000 was doing.
I use Orbi in AP mode, because I need a router with IPSEC site-to-site VPN capability and with L2TP remote access VPN capability. Orbi has neither of those features.
Using Orbi in AP mode is not a waste of money at all. I use Orbi for it's single discriminating feature--the wireless backhaul--and that feature is available in AP mode. I'm using Orbi because I cannot easily run wired Ethernet. If I could run wires I would use something else.
Right, your needs are almost certainly beyond the audience that the Orbi is aimed at. The people that I've personally interacted with needed a normal home router which had really good WiFi coverage. Hell, I bought it because I needed a stronger signal in an aluminum sunroom and ports for a couple of computers near it.
cinek wrote:I'm talking about the wireless speed here
Let's start with acknowledging that Orbi is towards the top part of most tests but accordin to smallnetbuilder, others aren't so bad:The 5GHz tests show relatively low variance and 2.4GHz are a bit more mixed.
- spinkickSep 12, 2017Apprentice
Again, I'm using orbi for its strength, strong backhaul, wifi speed and coverage. Orbi is one of the fastest out there. Routing is not Orbi's strength, its meant for home networks so its not really much of a router (at least the functions are not exposed to the home user for that).
I use a sophos UTM box Which lets me do a lot more things including a lot more security than what an Orbi can do. Servers, etc.
Nope, Orbi is faster than most AP's out there, thats why I'm using it as an AP only as well.
spinkick wrote:Again, I'm using orbi for its strength, strong backhaul, wifi speed and coverage. Orbi is one of the fastest out there. Routing is not Orbi's strength, its meant for home networks so its not really much of a router (at least the functions are not exposed to the home user for that).
I'm really curious what special routing is needed. I'm not trying to be rude but I just don't see what real world needs would be. Like I know for business grade hardware the needs/capabilities are much much greater but for a normal house I honestly can't see what those would be.
For me, intrusion prevention, antivirus at the gateway. I am a computer consultant so I'm more interested in network security than most, I suppose.
spinkick wrote:For me, intrusion prevention, antivirus at the gateway. I am a computer consultant so I'm more interested in network security than most, I suppose.
OK, that makes sense especially in your line of work.
- madbrainSep 15, 2017Luminary
The review is for the RBK40/RBK30, not the higher end RBK50 kit.
- 4redstarsSep 15, 2017Guide
I have to say the new firmware made a difference. So much so that I didn't even realize it happened and just didn't notice things got a lot more stable in my house.
Good job! So far.
