rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
cinek
Sep 12, 2017Apprentice
I'm talking about the wireless speed here
tomsliwowski
cinek wrote:I'm talking about the wireless speed here
Let's start with acknowledging that Orbi is towards the top part of most tests but accordin to smallnetbuilder, others aren't so bad:
The 5GHz tests show relatively low variance and 2.4GHz are a bit more mixed.
- madbrainSep 15, 2017Luminary
Let's start with acknowledging that Orbi is towards the top part of most tests but accordin to smallnetbuilder, others aren't so bad:The 5GHz tests show relatively low variance and 2.4GHz are a bit more mixed.
The review is for the RBK40/RBK30, not the higher end RBK50 kit.
- 4redstarsSep 15, 2017Guide
I have to say the new firmware made a difference. So much so that I didn't even realize it happened and just didn't notice things got a lot more stable in my house.
Good job! So far.
