rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
tomsliwowski
Sep 12, 2017Apprentice
spinkick wrote:Again, I'm using orbi for its strength, strong backhaul, wifi speed and coverage. Orbi is one of the fastest out there. Routing is not Orbi's strength, its meant for home networks so its not really much of a router (at least the functions are not exposed to the home user for that).
I use a sophos UTM box Which lets me do a lot more things including a lot more security than what an Orbi can do. Servers, etc.
I'm really curious what special routing is needed. I'm not trying to be rude but I just don't see what real world needs would be. Like I know for business grade hardware the needs/capabilities are much much greater but for a normal house I honestly can't see what those would be.
spinkick
For me, intrusion prevention, antivirus at the gateway. I am a computer consultant so I'm more interested in network security than most, I suppose.
- tomsliwowskiSep 12, 2017Apprentice
spinkick wrote:For me, intrusion prevention, antivirus at the gateway. I am a computer consultant so I'm more interested in network security than most, I suppose.
OK, that makes sense especially in your line of work.
