DarrenM
Dec 22, 2017Sr. NETGEAR Moderator
Firmware V2.1.1.16 auto update
we'll be removing the v2.1.1.16 firmware from the auto update server over the holidays and will resume pushing it in the new year. Firmware will still be available on product support pages for manual...
atiq332
Jan 04, 2018Star
ok i tried now to downgrade to v1. will test all again and if its work will wait to checked the stable orignal firmware comes. otherwise will keep the factory default
bcampbell83
Jan 04, 2018Star
The other thing you'll need to make sure you do if you do rollback is that you disable automatic updates.
You can follow this post, which worked for me: https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/m-p/1323973/highlight/true#M10304
