Sweetmo
Mar 21, 2020Tutor
Firmware V2.3.5.32
Today (3/21/20), I had an issue with my Orbi RBR40 connecting to internet, so I immediately went to the app and saw a note indicating new firmware was available. After two attempts to leverage the ...
Jetfree
May 19, 2020Aspirant
Hi all, my RBK40 setup is also facing the same internet drops after about a month of FW upgrade. It usually happens once every few days but it happened twice in the same day today. Previously, I have tried power cycling both the modem and router. It didn't last long. I'm very hesitant about carrying out a factory reset on the router. Not even sure if it will cure this problem for good. Is it possible to revert to the old FW?
- FURRYe38May 19, 2020Guru - Experienced User
Please try a factory reset and setup from scratch with the RBR and RBS.
Most current version of FW is v16:
What others have said about v16:
