AniDutta
Feb 22, 2017Apprentice
Firmware Version 1.5.0.12 issues/fixes
New firmware released on Feb 22, 2017. Starting this thread so people can chime in. And hopefully Netgear moderators read our feedback. I'll start: Update process went smoothly. Tha...
Narkhelek
Feb 22, 2017Aspirant
Upgrade went well using the built-in firmware update process.
- dpdurstFeb 23, 2017Luminary
As well update went smooth with no issues or problems and everything is back online running fine
- gatorgrad84Feb 23, 2017Initiate
Not so good for me...upgrade went smoothly, but now having issues with all IOS devices dropping connections. Not happeneing before upgrade. May need to revert back to prior version until fixed.
- fljoemonFeb 23, 2017Guide
How is everyone retaining the settings on the router that you have changed manually after the firmware gets updated? Do you manually re-enter the settings you changed or do you save some kind of a configuration file and then re-load it back after the firmware update.
Thanks!
