DatabaseJase
Dec 16, 2019Luminary
Firmware Version 2.5.1.8
Netgear have released a new firmware update for RBS50/RBR50 here: https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8 No mention of specific fixes to device labelling and r...
bdela
Mar 21, 2020Aspirant
I’ve been having a lot of issues with WiFi handoff between router/satellites since this update. Never had any issues before and now most devices don’t hand off when I’m moving around my home—I end up having to disconnect and reconnect to WiFi. Anyone else having this issue?
Mar 21, 2020Guru - Experienced User
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
Has a factory reset and setup from scratch been performed since last FW update? IF this doesn't resolve anything you can downgrade back to last working FW version.
