JeriD
Dec 07, 2019Star
Forcing Guest SSID to be 2.4
Hi - I have seens lots of posts to talk about how you can manually go into debug mode and setup separate SSID's for various purposes. However, I've been unable to force my Guest network to only suppo...
JeriD
Dec 11, 2019Star
Hi,
I went to disable the SSID 5 broadcast and it is not clear that you can do that for the guest network without disabling the 2.4 also. I want all of these bulbs on the guest network for security reasons and I only see one option for disabli/ng the SSID broadcast whereas for the primary network you can disable the two frequencies separetely. Therefore, I assume it disables both on guest? Can someone confirm before I try this? thanks.
SW_
Dec 11, 2019Prodigy
You can give separate SSIDs on Guest Network a shot and see if that solves the problem.
- JeriDDec 12, 2019Star
I will try this over the weekend and report back. Thanks.
- JeriDDec 13, 2019Star
I followed the instructions at the link provided exactly (https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1835472#M78008) without success. When I connected with my phpne to what was supposed to be the 2.4 guest ssid, it did connect to the guest network but at 5G, not 2.4. Is it possible that on my router (RBR40) wlg0 is the wrong interface to change?
- SW_Dec 13, 2019Prodigy
JeriD wrote:I followed the instructions at the link provided exactly (https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1835472#M78008) without success. When I connected with my phpne to what was supposed to be the 2.4 guest ssid, it did connect to the guest network but at 5G, not 2.4. Is it possible that on my router (RBR40) wlg0 is the wrong interface to change?
I don't have RBR40, but you can quickly verify the interface via telnet cmd.
- config show | grep ssid=*
root@RBR50:/# config show | grep ssid=*
wla1_ssid=NEST
wlg1_ssid=NEST24GHzYou can swap them you see 2 Guest Network SSIDs.
Good luck!
