JeriD
Dec 07, 2019Star
Forcing Guest SSID to be 2.4
Hi - I have seens lots of posts to talk about how you can manually go into debug mode and setup separate SSID's for various purposes. However, I've been unable to force my Guest network to only suppo...
JeriD
Dec 13, 2019Star
Thanks for the continued help with this. The below output is the result of the config show command. I may have fouled these up based on earlier experimentations which may be part of my problem. Wherever I have ZZZZZ below is where i defined a SSID Name. All others are from the system. This entry had something defined but not from me: wlg_arlo_ssid.
Can someone confirm in the below entries for certain which are the four settings that are for the SSID's below that matter ? (2 for primary network and 2 for the guest network). Then I can make sure I set the correct setting for Guest 2.4?
Thanks again.
root@RBR40:/# config show | grep ssid=*
bridge_wl_ssid=NETGEAR-Bridge
wla_ssid=ZZZZZ
wla_2nd_ul_bssid=
wlg_ul_bssid=
wla_ul_bssid=
wlg_ext_ssid=
wla_ap_bh_ssid=NETGEAR_ORBI_hidden80
wlg_ap_bh_ssid=NETGEAR_ORBI_hidden80
wan_brig_ssid1=0
wan_brig_ssid2=0
wla_sta_ssid=NETGEAR_ORBI_hidden80
wlg_sta_ssid=NETGEAR_ORBI_hidden80
endis_ssid_broadcast=1
wl1_2nd_ssid=ZZZZZ
wla_2nd_ssid=ZZZZZ
wl_ssid=ZZZZZ
wla_2nd_endis_ssid_broadcast=1
wlg1_ssid=ZZZZZ
wan_brig_guest_ssid1=0
wan_brig_guest_ssid2=0
wlg_arlo_ssid=[there was a name here but I didn't create it. Possibly system generated?]
wla1_2nd_ssid=ZZZZZ
Mayhugh1
Dec 14, 2019Apprentice
If it's just a one time set up issue for a 2.4 gHz device that requires the mobile device to be on 2.4 GHz, wouldn't just walking away from the router until the mobile device switches to 2.4 Ghz work? Or, is the problem that the device can't communicate with the network later once it's set up and the mobile device is back on 5GHz?
I'm considering buying a weather station whose instructions say 5 GHz must be turned off to set the device up, but they don't mention whether it will see the network later after I do mange to set it up. I've read about these issues others complain anout, but I'm not clear about whether the problem is with initial setup or also with later using the device. - Terry
- CrimpOnDec 15, 2019Guru - Experienced User
Creative and simple, yes. Going to work? Maybe not.
These Internet of Things devices get set up when they create their own WiFi access point, usually featuring the brand name to make it easy to recognize. Getting the phone far enough away from the Orbi to make the phone switch to 2.4G may also take the phone so far from the device that it cannot join the device WiFi access point. For example, to get my Sony phone to switch from 5G to 2.4G, I had to walk outside and out of my own yard.
I still favor this strategy:
- Avoid purchasing devices which have lots of user reviews complaining about how difficult they were to connect to WiFi.
- If somehow I get a device that simply will not connect, even when I ignore warning messages about 2.4G and keep pressing "Continue", then do the "Disable 5G SSID broadcast" process.
- SW_Dec 15, 2019Prodigy
Right - Just one minor point to be aware of.
One potential annoying problem with disabling 5GHz broadcast is that it could knock all other IoT and streaming devices to 2.4GHz if they're dual bands capable. When that happens, you might have to play the same trick by disabling 2.4GHz broadcast to force them back on 5Ghz. Then reenable 2.4Ghz broadcast afterward. Your WiFi network might take a while to settle down from such chaos.
Alternately, I can also reboot all NEST thermostats/streaming/gaming devices manually, but it's not easy to reboot NEST doorbell camera once it's switched to 2.4GHz. I have to take it off the wall with a tiny pin, stick/hold the pin through its tiny hole in back to reboot it, then tug the wiring back and snap it back on.
With separate SSIDs, we only need to change the SSID to force/steer them manually from one band to the other or even to nearest satellite if needs be. Disabling 5GHz broadcast is definitely simpler!
(Caveat: I have not tried this because all my IoT devices connected without problems.)
Temporarily stopping the 5G SSID broadcast should not affect any 5G devices that are already connected and working. There are instructions on many platforms for how to join a "hidden" WiFi network. That implies (to me) that once joined, they keep working.
Guess I can experiment with this (when the family is out of the house!)
Good point!
That will depend on how Orbi implements that feature. If Orbi doesn't disable the 5GHz radio and merely hides 5GHz SSID from clients, then it's a hidden 5GHz network and should continue to work normally as you've described.
- michaelkenwardDec 15, 2019Guru - Experienced User
True. The SSID broadcast exists to make life easier for wifi clients to find the source. Disabling SSID broadcast does not mean that the SSID is not there for devices to connect to it.
This is easily tested. Disable the SSID broadcast, then connect to the SSID by entering its name and password. Voila!
Some people use this as security feature. That may be why it exists.
The bottom line is that disabling SSID broadcast is not the same as turning off the 5 GHz wifi.
Disabling SSID isn't going to knock off existing wifi clients unless the people who wrote the software for the thing are terminally incompetent. Sadly, the skills of some of these people make this an all too likely event.
The clue is in the "button" you have to press.
It says Enable SSID Broadcast.
The manual makes it even clearer:
If you clear this checkbox, that creates a hidden network.
Thanks michaelkenward & CrimpOn!
I'll use this to hide all my IoT devices from the public. I'll disable SSID broadcast on my Guest Network and see how it goes.
- JeriDDec 15, 2019Star
Thanks again to all with suggestions. I wasn't able to test further because my network was too busy with family using it (at least during my waking hours). Next time I am home and can take down the network, I will backup my current settings and try to determine the correct interface so that I can determine how to create the separately named Guest network SSID. But honestly at this point, following one of two suggestions made above may actually be less hassle:
- Buy different bulbs that are easier to configure.
- Buy a cheap 2.4 access point to use just while configuring.
I will still just so I can close this out see if i can get SSID Guest broadcast disabled for 5G network only and report back.
Yes - Those two options are definitely simpler and less risky.
temporarily stopping the 5G SSID broadcast should not interfere with other users. Remember, the "key" step is to tell your smartphone to "forget" the Orbi WiFi and then search for nearby WiFi networks. The Orbi 2.4G will pop up, and the smartphone should connect at 2.4G.
- SW_Dec 16, 2019Prodigy
michaelkenward wrote:
CrimpOn wrote:Temporarily stopping the 5G SSID broadcast should not affect any 5G devices that are already connected and working.
I put this theory to test last night with my Orbi setup and disabled SSID broadcast on my Guest Network. The result is a mixed bag!
After disabling SSID broadcast last night, it has knocked one of my NEST thermostats offline this morning. Even after a manual rebooting the thermostat, it didn't connect to the hidden network either. After manually entering the SSID/password info again, it's able to connect and has been back online since.
I just manually rebooted the other thermostat to see if it'll automatically reeconnect to the hidden SSID, it didn't. Bummer!
