naccnacho's avatar
naccnacho
Follower
Dec 23, 2017
forgot wifi password
i have recently changed the wifi password to my orbis wifi and now i dont remeber it and cant connect to it
  • Perhaps if you plug your laptop into one of the Ethernet jacks, and access the Web UI, you can look at the UI and remind yourself.
  • If you can't get into the admin UI via a wired connection, then perhaps your option of last resort would be to reset to factory defaults and set everything up from scratch. Good luck!
