naccnacho
Dec 23, 2017Follower
forgot wifi password
i have recently changed the wifi password to my orbis wifi and now i dont remeber it and cant connect to it
- guzzijasonApprentice
If you can't get into the admin UI via a wired connection, then perhaps your option of last resort would be to reset to factory defaults and set everything up from scratch. Good luck!
- webminsterLuminary
Perhaps if you plug your laptop into one of the Ethernet jacks, and access the Web UI, you can look at the UI and remind yourself.
