priverapomar
Nov 06, 2018Tutor
FOSCAM FI9900P can't connect wifi to RBK40
Hi Guys
It is my first time with Orbi. Originally my wifi network was namaged by TP-Link Archer C60, so I have decided replace by Netgear.
Anyway, some issues happen when I try to connect...
- Nov 07, 2018
Ok, thanks for letting us know.
priverapomar
Nov 06, 2018Tutor
Hi FURRYe38, thanks to quick answer
Currently I have RBK43 (router an two satellites) with FW V2.2.1.210 over all of them. The internet access come from CISCO DPC3825 by Cable and Cisco is configuring as Bridge internet connection. The Orbi RBK40 is my main router. I'm covering around 433 Sq ft and around this sizing I have the Foscam Cameras.
Channels are setting as "Auto" and the router has taken Channel 13. The Wireless Security used is by defult providing by Router (WPA2-PSK [AES]).
Let me try with any stuff of configuration suggested by you. Anyway, in the mind time, let me know if you need more details or information about my Orbi configration.
Thanks a lot
Nov 06, 2018Guru - Experienced User
433 sq ft? Do you have both satelites enabled as well? This kind of size if correct, you only need the base router.
