surajdev
May 18, 2018Guide
Frequent network drop on Orbi RBK50
 Hi
 I recently purchased an Orbi router + satellite - the RBK 50 - 100INS Home Wi fi System.
 Setup and installation was a breeze - probably the only thing enjoyable of the product!
 We are expe...
May 18, 2018Guru - Experienced User
What channels are you using?
Any wifi neighbors near by? if so, how many?
What is the distance between the router and satellite(s)?
surajdev wrote:
Hi
We are experiencing network drops on all our devices - Windows laptops, iOs iphone and ipads, Smart TVs, etc. The network will work fine for 10 minutes or so and immediately drop ! This issue has persisted for the past 7 days. I have tried factory reset and the issue still lingers.
Both the router and the satellite are in the latest firmware.
Please provide a solution to my problem. I googled this issue and was appalled to see that so many people have the same issue as well. Hope Netgear is working with a permanent solution.
We do not have any devices connected via ethernet cable - all devices are connected using Wi fi only.
Please help!
- surajdevMay 18, 2018Guide
I am using both channels - 2.4 and 5Ghz. There are some Wifi neighbours around - 3 to 4 on the road that I live in, but that shouldnt be a problem, as my previous setup worked smoothly. The distance between my router to my satellite is approximately 25 - 30 feet
