surajdev
May 18, 2018Guide
Frequent network drop on Orbi RBK50
 Hi
 I recently purchased an Orbi router + satellite - the RBK 50 - 100INS Home Wi fi System.
 Setup and installation was a breeze - probably the only thing enjoyable of the product!
 We are expe...
May 18, 2018Guru - Experienced User
What channels are you using? Auto or 1, 6 or 11 on 2.4Ghz and ## on 5Ghz? Try 48.
2.4Ghz and 5Ghz are frequencies, not channels.
Let us know how it goes after the factory reset and set up from scratch.
PaulK617
May 18, 2018Star
I am having same problems with connection dropping. Before the v214.10 was released, I set my 2.4 bandwidth to channel 1, and 5.0 bandwidth to channel 48. That worked! Then after v2.1.4.10 was realeased I did a factory reset but it also reset my channels back to AUTO for both bandwidths. I thought it should be ok now with new firmware. But not. Now I’m experiencing same problems with dropped connections. I will change it back to channel 1 and 48 later today. Hope that will work. Will update later.
- surajdevMay 18, 2018Guide
at the moment i switched to channel 11 on 2.4Ghz and channel 48 on 5Ghz. All working fine, since half an hour. Will update in 24 hours!
