surajdev
May 18, 2018Guide
Frequent network drop on Orbi RBK50
 Hi
 I recently purchased an Orbi router + satellite - the RBK 50 - 100INS Home Wi fi System.
 Setup and installation was a breeze - probably the only thing enjoyable of the product!
 We are expe...
surajdev
May 18, 2018Guide
Oops sorry! so i should chose which channel on 2.4Ghz? Auto or 1,6,11?
PaulK617
May 18, 2018Star
You will have to try each channel out to see which is more stable. Channel 1, 6, and 11 are non overlapping channels. Depending on the interference in your area, certain channels will be more reliable. I would set it and monitor for 24 hours to see.
- surajdevMay 18, 2018Guide
So is channels the only reason for frequent network downing? and not the firmware versions as stated by everyone else???
- PaulK617May 18, 2018StarThere are many factors. I believe the firmware has the highest variable. Then there are setting that you could enable/disable as well as channels interferences. As customers we just want it to work reliably. Now everyone has a high level of networking aptitude. Network should work on making orbi login dummy proof. No offense to anyone but most people have basic networking IQ.
- surajdevMay 19, 2018Guide
Haha agreed :)
Yes, have powercycled both the router and the satellite. 12 hours in, not faced any problem as yet.
Also forgot to mention that I moved the satellite to within 10 feet of the router. Not sure if i should move it back to its original place of 30 feet away...
Will update in another 12 hours
 - PaulK617May 18, 2018StarAlso, power cycle both the modem and router to complete the process.
