surajdev
May 18, 2018Guide
Frequent network drop on Orbi RBK50
Hi
I recently purchased an Orbi router + satellite - the RBK 50 - 100INS Home Wi fi System.
Setup and installation was a breeze - probably the only thing enjoyable of the product!
We are expe...
surajdev
May 18, 2018Guide
So is channels the only reason for frequent network downing? and not the firmware versions as stated by everyone else???
PaulK617
May 18, 2018Star
There are many factors. I believe the firmware has the highest variable. Then there are setting that you could enable/disable as well as channels interferences. As customers we just want it to work reliably. Now everyone has a high level of networking aptitude. Network should work on making orbi login dummy proof. No offense to anyone but most people have basic networking IQ.
- surajdevMay 19, 2018Guide
Haha agreed :)
Yes, have powercycled both the router and the satellite. 12 hours in, not faced any problem as yet.
Also forgot to mention that I moved the satellite to within 10 feet of the router. Not sure if i should move it back to its original place of 30 feet away...
Will update in another 12 hours
- TomMacMay 19, 2018Guru
Channel made a diif for me too...good to hear it's working , tho IMO, 10 feet is kind of close ( unless signal is going thru a steel mesh wall )... 30 feet where you last had it placed is prob better ( as long as you getting a good backhaul signal listing from the main unt )
- tucsonticoMay 19, 2018Virtuoso
Channels can make all the difference in a crowded signal environment. Here's a great article regarding how WiFi handles traffic on similar channels:
Good Luck!
