reene11
Apr 08, 2022Follower
FTTP - is my Orbi good enough?
I have an RBK30 and satellite which has been running fine for years. I had FTTC and was pretty consistent across the house (80mb down, 20mb up). I upgrade recently to FTTP and my speeds are inconsis...
Itsonlyme
Apr 09, 2022Aspirant
There are a few things I would check first:
1. Are you running a speedtest.net via hardwired or wifi?
2. Check no other downloads/streaming are taking place at the same time when doing a speedtest.
3. Use another speedtest website to check results.
4. Try using your ISP router and do speedtests to rule out the Orbi.
Obviously with having FTTP there is no up to 10 day "training period" like there is with FTTC, so FTTP should instantly give you the max speed or it doesn't, it then comes to other issues like above.
