martyfp
Sep 22, 2017Luminary
FW 2.0.0.74 on download server
It looks like 2.0.0.74 is now on the download server, I'm not sure how this differs to the 2.0.0.72 that was posted by AmitR . Release notes look the same as was mentioned for 2.0.0.72 : https://...
Mikey94025
Sep 22, 2017Hero
Thanks for pointing out that the new 2.0.0.74 firmware is listed in the Orbi's support page: https://www.netgear.com/support/product/rbk50.aspx#download
My units are still at 2.0.0.72. I pressed the Check button on the Firmware Update admin page but they still report no new firmware version available.
martyfp
I've downloaded it and will manually install later... I am also on 2.0.072 and it has been very good so far.
- Hydro130Sep 22, 2017Luminary
martyfp wrote:I've downloaded it and will manually install later... I am also on 2.0.072 and it has been very good so far.
Thanks for catching this - I'll do the same.
.072 was working well for me too, but I'm curious -- do you have the "Implicit Beamforming" and "MU-MIMO" options checked? I'm experiementing both ways lately, and haven't noticed any consistent difference one way or another, but figured I'd ask you since yours has been stable too...
Thanks!
- martyfpSep 22, 2017Luminary
Yes I have beamforming and mu-mimo enabled. I also tried several variationsand did not see huge difference with them on/off. I just left them on and all seems OK.
FYI - I run in full router mode.
