ctmutlow
Dec 19, 2017Tutor
FW 2.1.1.16 Update broken backhaul
The update from 2.1.1.12 to 2.1.1.16 has reduced backhaul status to POOR from GOOD; not what you like to see really Sysyem configuration and positioning unchanged, tried both a reboot and resync ...
ctmutlow
Dec 19, 2017Tutor
Update:
Unticking the Enable Daisy-Chain Topology box (which had been enabled as default in earlier firmware) restored the link status to GOOD!
- tagteamDec 19, 2017Virtuoso
Honestly! Why do the latest firmware releases have that box checked by default? Sheesh!!
- vascoigneDec 22, 2017Aspirant
Hi,
Had exactly the same thing when updating the firmware to v 2.1.1.16.
Do we need or not to enable the daisy chain connection?
Don't like to have the satellite backhaul status to "poor"...
Thanks
- Hydro130Dec 22, 2017Luminary
If you only have one satellite, there's no point to enabling Daisy Chain. Leave it disabled.
If you have more than one satellite, but they are arranged in a hub-&-spoke manner aorund the router (i.e. S-R-S), then there is still no point in enabling Daisy Chain. Leave it disabled.
If you have multiple sats, but they need to talk to each other (i.e. R-S-S), then do enable Daisy Chain - that's the scenario it's deisgned to support.
I only have on sat, so I myself can't speak to how effective Daisy Chain acutally works.
