JoelM3d
Sep 16, 2017Tutor
Gigabit internet shows up as 400Mbps
I have Centurylink gigabit internet service to my house. I have my Orbi directly connected to my provided ONT. My pc which is connected by ethernet to my Orbi shows between 800Mbps and 900Mbps on the...
- Sep 17, 2017
Orib's client WiFi connection speeds are: 400 Mbps for 2.4 GHz and 866.7 Mbps for 5 GHz. You will only achieve a maximum of 50% to 60% of the connection speed as data throughput, due to overhead in the WiFi protocol. So, your results are normal. If you need maximum throughput, then wire your device to the Orbi router. Wired to the satellite should achieve around 500-600 Mbps, because the data must traverse the wireless backhaul.
st_shaw
Sep 17, 2017Master
rjeitani
Sep 17, 2017Aspirant
That doesn't explain why the upload speeds are half the download speeds. I had the same problem with my Orbi. Fixed it by putting it in AP mode (and had the Centurylink modem be the router with its radio off). Now I get 420mbps both up and down.
