JoelM3d
Sep 16, 2017Tutor
Gigabit internet shows up as 400Mbps
I have Centurylink gigabit internet service to my house. I have my Orbi directly connected to my provided ONT. My pc which is connected by ethernet to my Orbi shows between 800Mbps and 900Mbps on the...
- Sep 17, 2017
Orib's client WiFi connection speeds are: 400 Mbps for 2.4 GHz and 866.7 Mbps for 5 GHz. You will only achieve a maximum of 50% to 60% of the connection speed as data throughput, due to overhead in the WiFi protocol. So, your results are normal. If you need maximum throughput, then wire your device to the Orbi router. Wired to the satellite should achieve around 500-600 Mbps, because the data must traverse the wireless backhaul.
st_shaw
Sep 17, 2017Master
JoelM3d I understood what you wrote. Speeds of 200 to 400 Mbps are as expected. The achievable WiFi speedsactually has nothing to do with your Internet connection speed.
1. The 866 Mbps link rate means this is the MAXIMUM rate that the router and a client can exchange data. This rate is only achieved under ideal conditions, such as in the same room, no obstructions between devices, and with no sources of interference. This rate is not achieved through walls, etc. The rate also adjusts constantly with time, and will be different for communications from the router to the client, and from the client to the router. The connection from the client to the router is often less, especially with a phone, which has weak radio, poor antenna, and is blocked by your hand. This is why uploads can be less. As I wrote earlier, the expected THROUGHPUT is no more than 50% to 60% of the link rate, so the maximum you should ever see is 430 to 520 Mbps on 5 GHz and 200 to 240 on 2.4 GHz. This is because WiFi has a lot of management traffic that eats up the link rate. So, your WiFi results of 200 to 400 are in the normal range.
2. If you want to test and optimize your WiFi performance, then you should use a proper tool like iperf3. Download a copy of iperf3, run iperf3 as a server on a desktop or laptop wired to the router, and run iperf3 as a client on a WiFi laptop. On my iPhone 7+ connected to the Orbi router, I measure between 385 and 520 Mbps using iperf3 to a wired server connected to the Orbi router. I wouldn't use the Orbi speedtest or pay much attention to, as it's not measuring speed through the Orbi to your clients.
In your latest post you said you were only getting around 40 Mbps. That is lower than expected. Yes, I would try a reset. You might have other devices in the home causing interference though, such as neighbors' routers, wireless speakers, etc.
JoelM3d
Sep 18, 2017Tutor
st_shaw,
Thanks for the very indepth response, it is much appreciated.
After my last reply I ran a test in my living room and was getting 425Mbps. So everything seems fine according to your response.
I've moved my router up on a high shelf above my pc and reset to factory default with the latest firmware. Speeds near my router are now showing reasonable speeds again (350-250 range).
Thanks for all the replies and I'm very happy with what I'm now seeing.
- st_shawSep 18, 2017Master
JoelM3d Sounds like very good results. I hope it keeps working like that for you.
- rjeitaniOct 05, 2017Aspirant
This doesn't explain why upload speeds are abysmal when in router mode and only improve in AP mode. Getting 300-400mbps downloads for a gigabit connection is normal but 20-30 mpbs uploads for the same connection is not. This bug needs to be fixed. It's only when I use AP mode and turn off the routing that I get 400mbps for both downloads AND uploads. The post marked as the solution is not correct.
- st_shawOct 05, 2017Master
Yes, you should be getting more than 20-30 Mbps uploads in router mode.
After moving his router and performing a factory reset, the OP marked this thread as solved, because his issue was solved.
If you would like to create your own thread, and provide some more information on your specific issue, then perhaps someone can help you solve your issue.
