whoops
Jul 28, 2018Aspirant
Going beyond 4 Satelites with ethernet backhall
I called customer services, they said the Netgear Orbi is only guaranteed to work with a maximum of 4 satelites. They said although the router allows you to add more, if you go beyond 4 you will experience various problems due to "bandwith". I asked them if an ethernet backhall would overcome these problems but they insited no. However I am doubtful as to reliability of this answer, the guy I spoke too seemed low IQ. Please can someone advise. My ideal scenario is 6 orbi units conected by ethernet backhall, and up to three units sprinkled around using the mesh. My home is large but the real problem is my extremely think flint walls which absorb signal. Even on a mesh instead of ethernet backhall, the Linksys Duo supports 9 units, the Velop 10+, Google Home 17, eero say they are unlimited. I can't understand how the Orbi could fail with more than four it would have to be doing something very different. So I think the guy I spoke to was talking nonsense but I need someone who really knows the system to give me a true answer. Thanks very much
- waynealightApprentice
just buy 2 more satellites and try. the range is so powerful they might not of ever tested it.
you may also consider moving away from orbi and going to ubiquity unify. needing that many access points may require a higher level of equipment to really run properly.
- whoopsAspirantI have the router plus two satellite pack plus I bought the outdoor satelite. All are connected via ethernet backhall. However due to the thickness of the walls I need many more. I am renovating parts of the property, in these areas its easy for me to add ethernet backhall. Other parts are not so easy- hence my decision to go for a mesh capable system instead of paying someone to do a site survey and install ubiquiti networks 2.4ghz long range access points which would obviously be the ideal solution for thick wall penetration.
Does anyone know the answer to my question please. I don't want suggestions or complaints. I want to understand the three / four satelite limit on the netgear system which is the lowest limit on the market. How can there be such a low limit with an ethernet backhall? There is no explanation on the internet.- whoopsAspirantI should add that I was not aware of the limit when I bought the devices from netgear it is something I only just found out about as I was looking to expand and I have invested so much money in the system I don't want to start again.
Bandwidth will and can be a challenge as well as interferences and noise. If you have too many wifi signals in a close proximity, noise and congestion on wifi channels will become a problem and cause disconnets and wifi instability. You don't want too many wifi signal sources too close to each other. Wireless or wire connected satellites. Also the Orbi system seems to have a distance sweet spot in regards to how close the satelllites are to the base router. 30-40feet seems to be a good starting point for these systems when they are connected wirelessly. 4-6 satellites is good for a average home. If your using these for a business, then you not get what you desire as these are for a home setting. Maybe a small office. If you needing them for a Business, then you should looking into the Orbi Pro version or some other kind of wifi system meant and built for business.
Over all the Orbi is what it is and is designed for limited configurations. Anything beyond this could be problematic and not supported.
Good Luck
- budyLuminary
Ehh…? In what regard does this relate to the topic of wanting to install more than 4 satelites via wired backhaul?
Cheers,
budy
