ozunasawai4
Jun 12, 2020Follower
Good connectivity with V2.5.1.16
I almost don’t want to post this in case I jinx myself, but since the V2.5.1.16 firmware update for my RBR50/RBS50 + RBS20 set up (firmware applied to each), connectivity has been solid. 17 devices...
Jun 12, 2020Guru - Experienced User
Thanks for letting us know.
Just curious, was your FW updated via the RBRs web page automatically or did you manually select or manually apply the FW files?
Was a reset performed after the update or just update and continue?
