Gabe777
Sep 19, 2019Tutor
Gryphon wifi router connected to orbi satellite slow.
Hi,
My orbi router is connected to my AT&T wifi gateway (fiber 300 Mb) with 2 additional orbi satellites around the house. I was unable to update apps on mobile devices so turned off wifi on AT&T wifi gateway and changed my orbi to an access point. Afterwards, I can update and download apps now on wireless devices.
My question: I have a Gryphon wifi router that I use for parental control/monitoring hooked to an orbi satellite with ethernet cable broadcasting a different SSID than the orbi. The wifi speed test for Gyphon wifi router is much slower than orbi wif speedtest. Why is this happening?
Any advice or solutions to slow wifi on my Gryphon router would be greatly appreciated. Thank you!
so just to get this correct.
you're going:
Att gateway---->Orbi router (in ap mode)----->Orbi Satellite----->Gryphon router?
Is this right?
You also don't include much details. What model is this gryphon router?
- Gabe777Tutor
Basically what FURRYe38 wrote about. You've got the att device acting as router, then the orbi in AP mode (per your prior), and then the gryphon acting in router mode. You're running to many routers, running more than one nat, and probably creating some wifi interference. A poor choice for stability and performance.
Here's how I'd lay it out if you truly *need* the gryphon. Not sure why you need it as orbi has parental controls.
Make sure your att gateway is in passthrough or modem only mode. contact att to help you set this up. this will let you run your gryphon with all the parental controls you need. disable the wifi on it and just use the parental controls. Use the orbi in ap mode as its basically only acting as wireless anyway so have the gryphon by the router and the orbi be the wireless. Orbi should handle plenty of devices.
so like this:
att gateway (passthrough)----->gryphon router (disabled wifi)------>orbi router (ap mode)--->orbi satellites
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Gabe777 wrote:Hi,
- Gabe777TutorOrbi has already been configured to AP mode using your suggestion #3. Any ideas for fixing the slow Gryphon router on 2nd floor which is connected to orbi satellite? Thanks!
