rhester72
Nov 26, 2016Virtuoso
Guest isolation not supported in AP mode?
The good news: Guest access works. The bad news: You can't do guest isolation in AP mode, apparently - the option is greyed out. That makes it rather useless, unfortunately - why is this? ...
rhester72
Nov 27, 2016Virtuoso
I used to think so as well - except eero got this right. In AP mode, they use iptables to block any packets that aren't destined to TCP/UDP port 53 or DHCP broadcast to any local CIDR, based on eero's own IP addresses (v4 and v6). It's quite clever and works very well.
Rodney
TheEther
Nov 27, 2016Guru
Ok, I see how that could work. Thanks for pointing it out.
