rhester72
Nov 26, 2016Virtuoso
Guest isolation not supported in AP mode?
The good news: Guest access works. The bad news: You can't do guest isolation in AP mode, apparently - the option is greyed out. That makes it rather useless, unfortunately - why is this? ...
peteytesting
Feb 03, 2017Hero
TheEther wrote:
fbg wrote:I thinks this warrants some discussion. If client A tries to talke to client B, both on wifi, what happens? The frames don't go directly from A to B via radio (ignoring ad hoc mode wifi). They go to the access point / wireless router. If that access point is an Orbi in AP mode, the Orbi could either deliver the frames, or just send them out the wire and let the downstream router decide what to do with them. I don't know which one it does, and I can't test it since I'm still looking into buying or not... Ideally I would want the Orbi to offer either behavior as an option.
I would not expect the Orbi to simply send frames out the wire. It's possible that the downstream router will not even see the traffic, so it won't be in a position to isolate guest traffic.
Instead, I would expect the Orbi determine whether client A is on the guest network and either forward or drop the traffic accordingly at the base station. Netgear has a couple of ways they could implement this. A sensible way would be to have the satellite put guest traffic into a VLAN when sending over the Wi-Fi backhaul connection. The VLAN tag would clearly mark guest traffic. The base station could then look at the destination address of the traffic. If it's on the same subnet, then the traffic is dropped. If it's not local, then it sends it to the router to be forwarded to the Internet.
using the vlan tag would it also overcome the issue in ap mode as well ?
TheEther
Feb 04, 2017Guru
The VLAN tag could be used in either router or AP mode. It merely serves to easily identify guest traffic. How much extra work the base station needs to do in order to handle the guest traffic depends on whether it is in router or AP mode. In AP mode, the Orbi could apply the sorts of checks that rhester72 described several posts above. In addition, the it could also support an advanced mode whereby it doesn't strip the VLAN tag but, instead, forwards it to a router that understands VLAN tagging. The router could, then, enforce the traffic segregation. This is how some enterprise-class networking gear work.
- anschmidFeb 04, 2017Apprentice
VLAN tags for Guest Network will work. The Apple Airport devices use VLAN tag 1003 for the Guest Network to separate it from the main network traffic.
If you using the wireless device in AP mode this becomes a bit harder to configure on your main router/firewall and other network devices as they need to be able to understand and deal with the VLAN tag traffic rather than a different subsegment but it's entierly possible.
