Rumplestiltskin's avatar
Sep 26, 2017
Guest Network - Static Route?
Hi,
I have one last question before I take the plunge.... Is it possible to allow the guest network access to just one IP address on the main network, maybe by using a static route?
Thanks
Rumple
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Rumplestiltskin
    In the orbi settings its all or none when allowing the guest network to see the main network.
    DarrenM
    • Rumplestiltskin's avatar
      Rumplestiltskin
      Thanks.
      If the Orbi is in AP mode, is it possible for the router that it's connected to to differentiate between normal wifi and guest wifi, i.e, is it on its own subnet or tagged in some way?
      Thanks
      Rumple
