rp17
Feb 09, 2019Guide
Guest network xbox live
I have an Orbi RBR40 router with 2 satellites. I have a tenant that uses the guest network that has an Xbox. Xbox live will not work property on the guest network saying there is a problem with toredo or something along those lines. If I connect it to the regular network it works completely fine. Is there a way to enable this on the guest network? Thanks.
- Chuck_MMentor
Is IP6 enabled? Try disabiling it if your ISP doesnt support./
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
rp17 wrote:
I have an Orbi RBR40 router with 2 satellites. I have a tenant that uses the guest network that has an Xbox. Xbox live will not work property on the guest network saying there is a problem with toredo or something along those lines. If I connect it to the regular network it works completely fine. Is there a way to enable this on the guest network? Thanks.- rp17GuideI’ll check the version of the firmware when I get home but I’m positive it is the newest because I just checked. It is in router mode. It is a tplink-7610. I am pretty sure it’s not a modem issue considering it works fine on the regular WiFi network and just not the guest network. I also tested a guest network on an AirPort Extreme and that works without issue but it is just significantly slower so I don’t want to use it
Ok, was checking to see if the modem was NAT or not.
Guest Network should work, however I've seen other posts about Guest Network and how it operates. Seems to do some things a bit differently.
Can you first try the xbox connected to the main wifi first with Guest Network disable to see if the game console connects here. If it does, then try Guest Network again...
