dchbbc
Feb 26, 2019Apprentice
Guest network
I have a RBR40 with 3 satellites. I'm not sure why this model doesn't show up as a choice. I made a guest network. I have it disabled but I want to delete it completely. I can't find how to do this. Any help?
You need to log in to the routers web page using a PC or laptop and a web browser to disable Guest Network. SHould be under the Basic Tab or Advanced Tab.
- dchbbcApprentice
Hi. Thanks. I did that already and there is no disable, at least on mine. I tried to delete the name and password but it won't save without them. I guess I'll just have to leave it.
What browser are you using? There should be a check mark to enable or disable Guest Network.
You can do a factory reset ON the RBR and setup from scratch. Guest Network is disabled by default if I remember correctly.
