Net56
Oct 05, 2020Aspirant
Hard-set Orbi Channel Width
Hey everyone, I want to manually restrict Orbi's 2.4 and 5 GHz broadcasts to 20 MHz wide for selected center channels. I am aware of the default "Enable 20/40 MHz co-existance" option for the 2.4...
- Oct 05, 2020
The answer is no. However, depending on what PC, Laptop, etc you have, you can force what frequency you want to connect at. My Dell laptop allows me to force connect either 20Mhz or 40Mhz on 2.4Ghz and 80Mhz only on 5Ghz.
CrimpOn
Oct 05, 2020Guru - Experienced User
Net56 wrote:Also, it appears others are saying Orbi, by default, tries to automatically select up to 80 MHz channel width on the 5 GHz front and back haul bands (5.2 and 5.8 GHz, respectfully), depending on what it senses during its scans. Supposedly this is to allow maximum throughput to end-users.
I read one comment that when the user selects "36" from the 5G channel selection, that means (literally) 36 and nothing else. When they select a higher frequency, that means everything from 36 up to here. So, selecting 48 would be the only way to get a full 80mb channel.
There may be a method using telnet to specify the 5G backhaul frequency in the same way.
A little puzzled that frequencies in the "unlicensed" consumer band would interfere with a WISP backbone, which one would think would be in licensed frequencies and use very narrow band antennas. Supposing that you restrict one Orbi to a 20mb 5G channel, what about the hundreds of other residential WiFi systems in the path?
