jcxmartin's avatar
jcxmartin
Hardware warranty support
I have an Orbi RBK50 that is under hardware warranty, but when I try to submit a warranty support request through the Netgear support website, the site displays an error.  Very frustrating, as there appears to be no other way to contact Netgear for hardware support.
About once a day, I notice that my internet speeds (on all WiFi connected devices) fall to about 90mpbs (whereas they normally reach about 250-300mpbs on my 1 gigabit incoming internet service).  This speed degradation is evident on phones, windows PCs, and Macs that are connected to the WiFi.
I am able to consistently solve the problem by disconnecting the "Internet In" ethernet cable from the main Orbi router.  I just remove it for a few seconds, then plug it back in, and my WiFi internet speeds return to the normal 250-300mpbs level.
This is obviously an inconvenience, and it's not how the product was designed to work, which leads me to believe there is a hardware issue.
Note that the main router and all three satellites are on firmware 2.7.5.4.
Netgear, how do I get in touch with you to submit a support request under the hardware warranty?
  • FURRYe38's avatar
    May not be a HW problem, lets check this first...
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Circle, Traffic Meter.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    There is a reason why Orbi has cts set to 64 and that is to help with 1+3 and 1+4 configurations to avoid satellites clashing with each other
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
    Press the back reset button for 15 seconds then release.
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    • jcxmartin's avatar
      jcxmartin
      The modem is an Arris SBV3202.
      Cable is CAT6 and new.
      Home is 3500 sq ft.
      Distance between main router and satellites is over 30ft.
      2.4G channel is Auto.
      5G channel is 48.
      No WiFi neighbors near.
      Armor is off.
      As for all those other suggested changes to settings -- seems peculiar that for such a basic WiFi set up such as mine that the factory defaults would require such significant adjustments.
      • FURRYe38's avatar
        For that size of home, only the RBR and one RBS would be needed. I can use same RBK50 series I have in my 5000sq ft home with just one RBS and still have great wifi coverage and services.
        Try using manual channel 1 and 40
        Sometimes after a FW update, a factory reset and setup from scratch maybe needed if problems are seen.
  • michaelkenward's avatar
    michaelkenward
    What error?
    As FURRYe38 suggests, that sounds more like a local issue than anything wrong with your device.
    Put some work into troubleshooting that and you may save a lot of hassle with the RMA process.
