TonyLehner's avatar
TonyLehner
Follower
Jan 09, 2021
Hardwire a satellite RBS50
Can you hardwire an Orbi satellite RBR50 running V2.5.2.4 directly to the network to increase signal strength?  Or do you have to hardwire the router to the satellite?  If you did this, not sure where the input on the satellite would go. I guess you can hardwire two satellites together but not sure where to put the input on the second one.  Is there a signal strength advantage to any of this over using the WiFi?
