808rafael
Dec 29, 2016Tutor
has anyone been able to download the new ORBI firmware ?
I recently purchased a new ORBi System and have benn having trouble dowloading the latests firmware. I tried dowloading the firmware to my PC and doing a manual download but no luck.? So I was wond...
twocybers
Dec 29, 2016Star
Yes - poking iafter going to OrbiLogin.com and saw the option to register my product.
Here is the link at which I entered the Serial Number of my Base Station on the way to the download. WATCH model numbers carefully. There is only one character difference between the base and satilliate names/numbers.
http://downloadcenter.netgear.com/#searchResults
Immediately after registering I got a screen which sent me to the manual download page. That page contained the two links below. A word of warning/information. You can only perfom one update at a time - one satillite at a time and the based also separately.
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.4.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.4.0.18.zip
- Hydro130Dec 29, 2016Luminary
Good info from twocybers above... I would only add that when manually updating the firmware, I recall reading that you should update the satellite(s) first (using the ... RBS50.. file) , then the do the router last (using the ...RBR50... file).
That's how I've always done my manual updates using those zip files, and it's worked well every time.
Cheers, Chris
- twocybersDec 29, 2016Star
I hope the order updating is not critical - I did my base station first - I seriously doubt one can undo a firmware update.
- MarkC1024Dec 29, 2016Luminary
They do suggesting doing the satellites first, but I'll presume that is so you have access to the main router in case of a problem on one of the satellites.
