808rafael
Dec 29, 2016Tutor
has anyone been able to download the new ORBI firmware ?
I recently purchased a new ORBi System and have benn having trouble dowloading the latests firmware. I tried dowloading the firmware to my PC and doing a manual download but no luck.? So I was wond...
Hydro130
Dec 29, 2016Luminary
Good info from twocybers above... I would only add that when manually updating the firmware, I recall reading that you should update the satellite(s) first (using the ... RBS50.. file) , then the do the router last (using the ...RBR50... file).
That's how I've always done my manual updates using those zip files, and it's worked well every time.
Cheers, Chris
twocybers
Dec 29, 2016Star
I hope the order updating is not critical - I did my base station first - I seriously doubt one can undo a firmware update.
- MarkC1024Dec 29, 2016Luminary
They do suggesting doing the satellites first, but I'll presume that is so you have access to the main router in case of a problem on one of the satellites.
