808rafael
Dec 29, 2016Tutor
has anyone been able to download the new ORBI firmware ?
I recently purchased a new ORBi System and have benn having trouble dowloading the latests firmware. I tried dowloading the firmware to my PC and doing a manual download but no luck.? So I was wond...
808rafael
Dec 30, 2016Tutor
So last night I was still having the same issues downloading the lastest firmware. Every time I hit the search for update the only update available was the router but not the satallite. So I got in touch with one of the Techs from Netgear and they walked me though the installation. So the process I followed was the manual install of the firmware. I first downloaded the satallite and then it automatically download the router as well. It was a really easy process now I am happy to be running the latest update. Specially because it now supports guest network which was one of my biggest complaints about the system. Overall I just got this system and it has solved all my wifi issues. Right after the update I tested the speed on my iPhone 7 plus and got 410 Mbps. Never have I seen a speed like that on a phone. My old router was only giving me about 150 Mbps. So this is a huge update and the webpages take less than a second to come up amazing pcs of tech. The
- twocybersDec 30, 2016Star
Would you mind telling how you got in touch with a tech from Netgear? I casually looked and did not see any way. Don't have any issues, but if I do it will be nice to know how.
- 808rafaelDec 30, 2016Tutor
I just went to the NETGEAR WEBSITE SCROLLED TO THE BOTTOM AND THE CONTACT TAB HAD THE TECH SUPPORT NUMBER.
I looked again and found several different pages with a "Contact Support" and "Contact" links. I found no "Contact" Tab. Since ther are several pages with Contacts links, how about a URL or directions on how to get there?
