Pmcgarryuk
Sep 12, 2018Aspirant
Having an issue with Orbi 2nd satelite
Hi, so I have a bit of a WiFi not spot. So I had the solution to get a satellite.
I noticed that a complete system was same price as satellite. So I bout the 2nd system as I thought. Brilliant 2 sa...
Sep 12, 2018Guru - Experienced User
What is the FW currently loaded on the current Orbi system and satellites?
You sould need to probably update the FW on the newer satellite if it has never been udpated...
Pmcgarryuk
How can I achieve this if it won't connect in the first place?
- Christian_RSep 12, 2018NETGEAR Employee Retired
- PmcgarryukSep 12, 2018AspirantOriginally a router and satellite, then I purchased another router and plug in satellite.
Given I can't use the 2nd router I am hoping to use the plug in satellite. So 1 router and 2 satellites.
Thanks
Paul- Christian_RSep 12, 2018NETGEAR Employee Retired
When you attempt to sync the additional satellite to the original router, what color is the LED ring on the additional satellite?
~Christian
