Pmcgarryuk
Sep 12, 2018Aspirant
Having an issue with Orbi 2nd satelite
Hi, so I have a bit of a WiFi not spot. So I had the solution to get a satellite.
I noticed that a complete system was same price as satellite. So I bout the 2nd system as I thought. Brilliant 2 sa...
Pmcgarryuk
How can I achieve this if it won't connect in the first place?
Christian_R
Sep 12, 2018NETGEAR Employee Retired
- PmcgarryukSep 12, 2018AspirantOriginally a router and satellite, then I purchased another router and plug in satellite.
Given I can't use the 2nd router I am hoping to use the plug in satellite. So 1 router and 2 satellites.
Thanks
Paul- Christian_RSep 12, 2018NETGEAR Employee Retired
When you attempt to sync the additional satellite to the original router, what color is the LED ring on the additional satellite?
~Christian
- PmcgarryukSep 13, 2018AspirantWhite pulsing
