atomarchio
Jan 30, 2019Tutor
Having issues with RBK30 satellite
I bought the Orbi about a year ago. Seemed to work fine until I bought a google mini home hub for 1st floor bedroom.
I am noticing that Google mini disconnects from network often. Trying to pl...
Jan 30, 2019Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
I am noticing that Google mini disconnects from network often. Trying to place the satellite in area closer to bedroom.
However, when I go to login page I keep seeing backhaul status and then it goes back to config sync. I am wondering if the satellite keeps disconnecting from network.
Is there another product I can buy to resolve this? Should I purchase a 2nd satellite for the specific room (bedroom) where the google mini can't connect?
Or should I replace the satellite with the larger one?
Please help. Thanks.
- atomarchioJan 30, 2019Tutor
The firmware is V2.2.1.210. Motorola Surfboard 6141
home almost 4500 sq ft. the distance between router and satellite is more than 30' I would guess probably closer to 50'.
However, I can't move satellite move closer to router because wifi coverage decreases in my home office which is on other side of house from router.
Would adding a 2nd satellite (in between router and 1st satelllite) resolve the issue?
Here are my channel settings.
2.4G Channel 6 2.4G Mode Up to 192 Mbps 5G Channel 36+40+44(P)+48 5G Mode Up to 866.7 Mbps - FURRYe38Jan 30, 2019Guru - Experienced User
Possible.
It might be easier to purchase RBS50 and then use that as wired access point in the room instead of the satellite.
Would that work? Are there any issues doing this with the main Orbi router?
Yes you can connect an RBS via wired back haul and use it at the remote location. This would work too.
