thebahlfam
Aug 23, 2018Aspirant
Help needed with Orbi RBK50!
Hello everyone. I have a three bedroom apartment that is approx. 1,500 square feet. The only [active] coaxial hookup is in one corner of the apartment. It's not an ideal spot, but it's what I have to...
Aug 23, 2018Guru - Experienced User
1. Do I need a second satellite? No, the router alone can cover around 30 feet. Since you have the router at one end and need a satellite at the opposite end, this will work fine. I have a similar placement.
2. If I do, is my proposed layout ok? No need for S1. Put base at Start and a satellite at S2. 30 feet is recommended in between them to begin with depending upon building materials.
3. Could adding a second satellite hurt my performance at all? Yes. You can't have too many over lapping wifi sources to close together.
AC641
Aug 23, 2018Luminary
I would stick with the Router where it has to be and use pass-through (those with a power socket built in e.g. Devolo dLAN 1200) Powerline Adpaters to hard wire your TV, PS4 etc - via a simple unmanaged switch (e.g. THIS) if necessary. Then place S2 where it gives you the best overall coverage.
- thebahlfamAug 26, 2018Aspirant
The powerline adapters idea is a good one. I have NETGEAR PowerLINE 1200 Mbps, 1 Gigabit Port (PL1200-100PAS). I would simply connect that to to my router and a switch, and then wire the components to the switch, right?
- AC641Aug 26, 2018Luminary
I would connect the Router to a Powerline Adapter with another Powerline Adapter for you TV, PS4 etc. This is where you want to add an Ethernet Switch and plug your TV, PS4 etc. into the switch. If the Powerline Adpaters are stable then great. I had Internet drops with my older ones (both Netgear and Devolo) i.e. non pass-through. I swapped them for the pass-through type as they're better at filtering mains noise - not a single issue since.
Thank you, all, for the suggestions and feedback.
If I decided to purchase an additional satellite and positions the router and satellites in a "triangle" at least 30 feet apart, would that be ok? With the proposed solutions and building materials in my house, I worry about the baby room (the bottom right in the attached screenshot) getting appropriate coverage.
Before deciding to get the RBK50, I had a Linksys wireless extended very close to the baby room (the router was in the same place). The wireless coverage in the baby room was awful. As a result, the Arlo Baby monitor delivered very poor performance.
