thebahlfam
Aug 23, 2018Aspirant
Help needed with Orbi RBK50!
Hello everyone. I have a three bedroom apartment that is approx. 1,500 square feet. The only [active] coaxial hookup is in one corner of the apartment. It's not an ideal spot, but it's what I have to...
Aug 23, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
thebahlfam wrote:
Hello everyone. I have a three bedroom apartment that is approx. 1,500 square feet. The only [active] coaxial hookup is in one corner of the apartment. It's not an ideal spot, but it's what I have to work with. I am planning on getting the RBK50 (router + one satellite). I wanted to use the satellite to hard-wire my entertainment system (TV, Bose system, PS4, etc.). I am worried that if I do that, the rest of my place won't have ample coverage.
My wife and I are expecting our first child in a few weeks and we purchased an Arlo Baby. I am especially concerned that there won't be ample coverage for the video/audio streaming that the Arlo Baby will require.
I've attached a floor plan of my place. The star is where the router has to go. S1 is where I'd like the satellite to go. S2 is where I would put a second satellite (if necessary). The baby's room is the 10' 12'4" room in the bottom right corner.
My questions for you all are:
1. Do I need a second satellite?
2. If I do, is my proposed layout ok?
3. Could adding a second satellite hurt my performance at all?
Thanks, in advance, for your help!
- thebahlfamAug 26, 2018Aspirant
The modem is an ARRIS SURFboard SB6190 Cable Modem.
- FURRYe38Aug 26, 2018Guru - Experienced User
Be aware of your ISP modem model. Its not a great modem:
