thebahlfam
Aug 23, 2018Aspirant
Help needed with Orbi RBK50!
Hello everyone. I have a three bedroom apartment that is approx. 1,500 square feet. The only [active] coaxial hookup is in one corner of the apartment. It's not an ideal spot, but it's what I have to...
Aug 23, 2018Guru - Experienced User
1. Do I need a second satellite? No, the router alone can cover around 30 feet. Since you have the router at one end and need a satellite at the opposite end, this will work fine. I have a similar placement.
2. If I do, is my proposed layout ok? No need for S1. Put base at Start and a satellite at S2. 30 feet is recommended in between them to begin with depending upon building materials.
3. Could adding a second satellite hurt my performance at all? Yes. You can't have too many over lapping wifi sources to close together.
AC641
Aug 24, 2018Luminary
I think you're confusing the minimum recommended distance between router and satellite with WiFi range. The WiFi range of both Router and satellite is far greater than 30ft. Of course the range in the apartment setting of the OP will depend on many factors, the main one being wall construction.
- FURRYe38Aug 24, 2018Guru - Experienced User
Yes, just simple information as the OP was asking about a 2nd satellite and for the size home he has, doen't need a 2nd satellite.
Building matierials are a given. However to some don't take this into account or unaware of the impact of building materials.
