thebahlfam
Aug 23, 2018Aspirant
Help needed with Orbi RBK50!
Hello everyone. I have a three bedroom apartment that is approx. 1,500 square feet. The only [active] coaxial hookup is in one corner of the apartment. It's not an ideal spot, but it's what I have to...
AC641
Aug 24, 2018Luminary
FURRYe38 wrote:
1. Do I need a second satellite? No, the router alone can cover around 30 feet. Since you have the router at one end and need a satellite at the opposite end, this will work fine. I have a similar placement.
I think you're confusing the minimum recommended distance between router and satellite with WiFi range. The WiFi range of both Router and satellite is far greater than 30ft. Of course the range in the apartment setting of the OP will depend on many factors, the main one being wall construction.
Aug 24, 2018Guru - Experienced User
Yes, just simple information as the OP was asking about a 2nd satellite and for the size home he has, doen't need a 2nd satellite.
Building matierials are a given. However to some don't take this into account or unaware of the impact of building materials.
