thebahlfam
Aug 23, 2018Aspirant
Help needed with Orbi RBK50!
Hello everyone. I have a three bedroom apartment that is approx. 1,500 square feet. The only [active] coaxial hookup is in one corner of the apartment. It's not an ideal spot, but it's what I have to...
Aug 29, 2018Guru - Experienced User
What is the distance between the babys room and the main router? The camera looks like the distance is well with in range.
You can lower the power output of the main router on the 5Ghz radio from 100% to 25% save settings then try a reboot on the camera to see if it connects to the 2.4ghz radio.
Possible that your camera could be not working well?
AC641
Aug 29, 2018Luminary
What are your Download/Upload speeds for your Internet connection? I would start looking at the Arlo Baby Monitor. With your system set up as descibed go into the baby's room with a phone, laptop etc and measure the speed you get in a similar position to the Baby monitor using something like Speedtest.net.
- thebahlfamAug 29, 2018Aspirant
I tested the speeds all over the property and they are pretty much the same. I guess the issue has to be the camera.
