Bing-Stroller
Oct 24, 2017Luminary
Help with Asus Compatibility and Orbi
Hi, I am seriously considering adding an Asus router to my setup for various reasons and after reading countless reviews I have narrowed it down to the following 3: ASUS RT-AC68U AC1900 Dual Ban...
Bing-Stroller
To clarify,
The Asus would be in router mode with WiFi turned off and the Orbi in AP mode with WiFi on.
peteytesting
Oct 24, 2017Hero
sure that works fine , its actually how i run my orbi as i depend on the aiprotect etc of the asus
as far as which asus , avoid the 87u as its problematic , and you dont reallyneed a tri band router in the rt3200ac , the rt-ac68u is ok but router wise i would be aiming at the fastest cpu and most ram you can afford , perhaps look at the rt-ac3100 or rt-ac86u if you can afford them
or as i said look at a dedicated none wireless router like a ubiquiti edge or micrtik router
