Bing-Stroller
Oct 24, 2017Luminary
Help with Asus Compatibility and Orbi
Hi, I am seriously considering adding an Asus router to my setup for various reasons and after reading countless reviews I have narrowed it down to the following 3: ASUS RT-AC68U AC1900 Dual Ban...
j1n
Jun 18, 2018Apprentice
After using the Orbi system for six months and talking with others in the Netgear Community, I’ve decided to try out using the Asus RT-AC86U Router in front of the Orbi System (I have the Orbi RBK50 + 2 sattelites and also the Outdoor Orbi satellite (RBS50Y). It sounds like you just put the Orbi system in AP mode and run the Asus router with the Wi-Fi disabled. Did you try this setup? If so, how is it working and also do you have any tips that you learned while using this setup? Thanks! Jason
