cwjones
Oct 29, 2018Aspirant
Help with Set-up RBK50 - Centurylink Fiber (Eliminate D2100T?)
I'm wanting to try to eliminate the Router that CenturyLink is "renting" to me for $10 a month and instead configure the Orbi to be the router. In reading random postings across the internet, it SOU...
jical80
Nov 03, 2018Aspirant
Were you able to successfully complete this setup?
"Set-up RBK50 - Centurylink Fiber (Eliminate D2100T?)"
Nov 04, 2018Guru - Experienced User
Have you tried any of the suggestions as well?
- cwjonesNov 04, 2018Aspirant
The majority of the solutions offered appear to not eliminate the CL Router, which was the goal. What I was hoping for was steps 1-10 of how to configure the Orbi Router so as to completely remove the CL Router from the setup (and thus return it to them and not have an additional piece of equipment to blame when things go wrong). I unfortunately don't have the time to be experiementing, which is why I was hoping someone else had figured it out.
I'll re-read in a bit and figure out if maybe I missed the obvious answer.
- FURRYe38Nov 04, 2018Guru - Experienced User
I would first contact your ISP to see if there router is needed. I believe in most cases there ONT/Router unit is required for operation with there services. If they confirm then, then your best options would be to try #2 and then #3 of the suggestions...
