jpmpls99
Jun 12, 2018Aspirant
Help with Set-up RBK50 - Centurylink Fiber
I am hoping that someone can provide set-up for a non-technical user. I was recently upgraded to Centurylink 100Mb service with Fiber. I do not (or won't soon) use CL phone service, nor do I use Prism. I have some sort of box (I assume a Optical Netowrk Terminator) and a C2100T modem/router in the basement of the house. I need coverage over about 3000 sqft. I purchased the Orbi Rbk50 and would like to use it to improve coverage as we have exponentially increased devices and streaming within the house of 4 people. Can someone provide the steps necessary to set up the Orbi router and satellite? Thanks for your help.
- st_shawMaster
I already gave you detailed steps in response to the post you made on dslreports yesterday.
A CenturyLink technician also weighed in with some information for you.
How about working with that information instead of duplicating things on here?
- jpmpls99Aspirant
Thanks for the response. I just wanted to make sure I fully understood. I had no idea the two forumns were so closely linked. No offense intended. I'm going to try it tonight.
- st_shawMaster
No problem. The forums aren't linked, but I've been a member of dslreports since 2000.
Let me know if you have any questions. My suggestion to use Orbi in Access Point mode is the easiest to setup with Century Link and will give you the full benefits of Orbi's WiFi coverage. I'd suggest starting with that first, to see how Orbi works for you. You can try the more complex setups later, if you decide you want to.
