Hermod69
Aug 03, 2021Aspirant
Hi ping with Nokia G-010G-Q fiber modem and Netgear ORBI RSR50
Hi.
I have internet from Telenor here in Norway. Currently fiber connection with a Nokia G-010-G-Q fiber modem delivering 360Mbps up and down. I have 1 RBR50 and onr RBS50. All devices have firmware version V2.7.3.22. Inhouse I have ethernet cabels to sattelite and to other devices around the house. Router is located in a technical room.
When pinging the ISP's DNS, the ping time is very unstable. As often from 5 to 500 ms. But sometimes it peeks up to 2000 and 3000 ms. I have connected a pc directly to the fiber modem and testet from there. The ping time directlyu from the fiber modem is then from 5 ms and under.
In addition of this, I have a cable decoder for TV. When I turn this on, the router is terminating all traffic and the streaming on the cable tv decoder is very poor.
Anyone help me with this 2 issues?
Hermod Svingerud
Whats the CAT version of cables being used? CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Has a factory reset and setup from scratch been performed since last FW update?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Is the cable TV decoder unit wireless or wire connected to the Orbi system? Wired would be preferred.
- Hermod69Aspirant
Hi,
I have not done a factory reset yet after last firmware update.
I use CAT 8 in my house.
The house is abaout 180 square feet divede in 2 floors.
The sattelite, RBS, is connected to RBR with cable. There is a switch between the devices.
The TV-Decoder is connected with cable. No option for Wifi yet.
What is the distance between the router and 📡?
What is the Mfr and model# of the ethernet switch in the configuration?
